Programmation des architectures hétérogènes à l'aide de tâches divisibles ou modulables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Programmation of heterogeneous architectures using moldable tasks
Hybrid computing platforms equipped with accelerators are now commonplace in high performance computing platforms. Due to this evolution, researchers concentrated their efforts on conceiving tools aiming to ease the programmation of applications able to use all computing units of such machines. The StarPU runtime system developed in the STORM team at INRIA Bordeaux was conceived to be a target for parallel language compilers and specialized libraries (linear algebra, Fourier transforms,...). To provide the portability of codes and performances to applications, StarPU schedules dynamic task graphs efficiently on all heterogeneous computing units of the machine. One of the most difficult aspects when expressing an application into a graph of task is to choose the granularity of the tasks, which typically goes hand in hand with the size of blocs used to partition the problem's data. Small granularity do not allow to efficiently use accelerators such as GPUs which require a small amount of task with massive inner data-parallelism in order to obtain peak performance. Inversely, processors typically exhibit optimal performances with a big amount of tasks possessing smaller granularities. The choice of the task granularity not only depends on the type of computing units on which it will be executed, but in addition it will influence the quantity of parallelism available in the system: too many small tasks may flood the runtime system by introducing overhead, whereas too many small tasks may create a parallelism deficiency. Currently, most approaches rely on finding a compromise granularity of tasks which does not make optimal use of both CPU and accelerator resources. The objective of this thesis is to solve this granularity problem by aggregating resources in order to view them not as many small resources but fewer larger ones collaborating to the execution of the same task. One theoretical machine and scheduling model allowing to represent this process exists since several decades: the parallel tasks. The main contributions of this thesis are to make practical use of this model by implementing a parallel task mechanism inside StarPU and to implement and study parallel task schedulers of the literature. The validation of the model is made by improving the programmation and optimizing the execution of numerical applications on top of modern computing machines.
Les ordinateurs équipés d'accélérateurs sont omniprésents parmi les machines de calcul haute performance. Cette évolution a entraîné des efforts de recherche pour concevoir des outils permettant de programmer facilement des applications capables d'utiliser toutes les unités de calcul de ces machines. Le support d'exécution StarPU développé dans l'équipe STORM de INRIA Bordeaux, a été conçu pour servir de cible à des compilateurs de langages parallèles et des bibliothèques spécialisées (algèbre linéaire, développements de Fourier, etc.). Pour proposer la portabilité des codes et des performances aux applications, StarPU ordonnance des graphes dynamiques de tâches de manière efficace sur l’ensemble des ressources hétérogènes de la machine. L’un des aspects les plus difficiles, lors du découpage d’une application en graphe de tâches, est de choisir la granularité de ce découpage, qui va typiquement de pair avec la taille des blocs utilisés pour partitionner les données du problème. Les granularités trop petites ne permettent pas d’exploiter efficacement les accélérateurs de type GPU, qui ont besoin de peu de tâches possédant un parallélisme interne de données massif pour « tourner à plein régime ». À l’inverse, les processeurs traditionnels exhibent souvent des performances optimales à des granularités beaucoup plus fines. Le choix du grain d’un tâche dépend non seulement du type de l'unité de calcul sur lequel elle s’exécutera, mais il a en outre une influence sur la quantité de parallélisme disponible dans le système : trop de petites tâches risque d’inonder le système en introduisant un surcoût inutile, alors que peu de grosses tâches risque d’aboutir à un déficit de parallélisme. Actuellement, la plupart des approches pour solutionner ce problème dépendent de l'utilisation d'une granularité des tâches intermédiaire qui ne permet pas un usage optimal des ressources aussi bien du processeur que des accélérateurs. L'objectif de cette thèse est d'appréhender ce problème de granularité en agrégeant des ressources afin de ne plus considérer de nombreuses ressources séparées mais quelques grosses ressources collaborant à l'exécution de la même tâche. Un modèle théorique existe depuis plusieurs dizaines d'années pour représenter ce procédé : les tâches parallèles. Le travail de cette thèse consiste alors en l'utilisation pratique de ce modèle via l'implantation de mécanismes de gestion de tâches parallèles dans StarPU et l'implantation ainsi que l'évaluation d'ordonnanceurs de tâches parallèles de la littérature. La validation du modèle se fait dans le cadre de l'amélioration de la programmation et de l'optimisation de l'exécution d'applications numériques au dessus de machines de calcul modernes.
COJEAN_TERRY_2018.pdf (4.39 Mo) Télécharger le fichier
tel-01816341 , version 1 (15-06-2018)
  • HAL Id : tel-01816341 , version 1
Terry Cojean. Programmation des architectures hétérogènes à l'aide de tâches divisibles ou modulables. Autre [cs.OH]. Université de Bordeaux, 2018. Français. ⟨NNT : 2018BORD0041⟩. ⟨tel-01816341⟩
370 Consultations
417 Téléchargements
