Simulations couplées fluide-structure et étude expérimentale d’un hydrofoil composite sous écoulement hydrodynamique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Coupled Fluid-Structure Simulations and Experimental Study of a Composite Hydrofoil Under Hydrodynamic Flow
This Ph.D is sponsored by the French company Naval Group in collaboration with LHEEA Laboratory from Ecole Centrale de Nantes and GeM Institute from ICAM de Nantes, and deals with the development of new composite marine propellers with improved efficiency, improved acoustic discretion and more environment-friendly. One of the key solutions lies in the application of composite materials to marine structures, in order to benefit from their reduced weight, increased flexibility and bend-twist coupling capacity. Indeed, the latter enables the shape-adaptability of the structure to passively adapt to the incoming flow. To meet this challenge, we first set-up a tightly coupled numerical fluid-structure method using two commercial CFD (Starccm+) and CSD (Abaqus) solvers on two flexible hydrofoils and we validated this method against experimental results available in the literature. Second, we specifically developed a composite hydrofoil to behave closely like a marine propeller and tested it in the hydrodynamic tunnel of the Ecole Navale. Thanks to the combined experimental and numerical analysis of this composite hydrofoil we reached the following conclusions: i) we helped demonstrate the industrial application of a state-of-the-art strain measurement technique using optical fibers directly embedded within the composite plies, ii) we provided some insights into the physics of the fluid-structure interaction occurring on composite hydrofoils and iii) we presented the current limitations of this coupled numerical fluid-structure method relatively to its industrial application.
Les travaux de cette thèse s’inscrivent dans le cadre d’une collaboration CIFRE entre Naval Group, le Laboratoire d’Hydrodynamique, d’Energétique et d’Environnement Atmosphérique (LHEEA) de l’Ecole Centrale de Nantes et de l’Institut de Génie des Matériaux (GeM) de l’ICAM de Nantes, sur la problématique de développement d’hélices marines plus efficaces, plus discrètes, et plus respectueuses de l’environnement. Une des solutions passe par le développement de structures composites plus légères et plus flexibles, capables de se déformer passivement pour s’auto-adapter à l’écoulement incident grâce à leurs propriétés spécifiques de couplage flexion-torsion. En lien direct avec cette problématique, nous avons réalisé les travaux de thèse en deux temps. Nous avons dans un premier temps mis en place, montré la faisabilité et validé une méthode de couplage numérique fluidestructure implicite fort entre les codes commerciaux de CFD Starccm+ et de CSD Abaqus pour un cas d'application issu de résultats expérimentaux disponibles dans la littérature sur deux hydrofoils flexibles déformables. Puis dans un second temps nous avons développé, réalisé et testé, dans le tunnel hydrodynamique de l’Ecole Navale, un profil portant composite spécifiquement conçu pour s’approcher du comportement d’une hélice. L’étude expérimentale et numérique de cette configuration nous a permis i) d’éprouver l'utilisation en milieu académique et industriel de nouvelles méthodes expérimentales d'instrumentation d'une pièce composite par insertion directe de fibres optiques dans les plis de composite, et d'une méthode mixte numérique - expérimentale de calibration fine d'un modèle numérique structure ; ii) d’apporter un éclairage sur la physique de l'interaction fluidestructure se produisant sur une surface portante composite ; et iii) de préciser les limitations actuelles concernant la diffusion en milieu industriel de cette méthode de couplage numérique fluide-structure.
L_PERNOD.pdf (37.67 Mo) Télécharger le fichier
tel-02390064 , version 1 (02-12-2019)
  • HAL Id : tel-02390064 , version 1
Laëtitia Pernod. Simulations couplées fluide-structure et étude expérimentale d’un hydrofoil composite sous écoulement hydrodynamique. Matériaux. École centrale de Nantes, 2019. Français. ⟨NNT : 2019ECDN0008⟩. ⟨tel-02390064⟩
477 Consultations
177 Téléchargements
