Reinforcement learning for Dialogue Systems optimization with user adaptation. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Apprentissage par Renforcement pour l'optimisation des systèmes de dialogue via l'adaptation à l'utilisateur.
The most powerful artificial intelligence systems are now based on learned statistical models. In order to build efficient models, these systems must collect a huge amount of data on their environment. Personal assistants, smart-homes, voice-servers and other dialogue applications are no exceptions to this statement. A specificity of those systems is that they are designed to interact with humans, and as a consequence, their training data has to be collected from interactions with these humans. As the number of interactions with a single person is often too scarce to train a proper model, the usual approach to maximise the amount of data consists in mixing data collected with different users into a single corpus. However, one limitation of this approach is that, by construction, the trained models are only efficient with an "average" human and do not include any sort of adaptation; this lack of adaptation makes the service unusable for some specific group of persons and leads to a restricted customers base and inclusiveness problems. This thesis proposes solutions to construct Dialogue Systems that are robust to this problem by combining Transfer Learning and Reinforcement Learning. It explores two main ideas: The first idea of this thesis consists in incorporating adaptation in the very first dialogues with a new user. To that extend, we use the knowledge gathered with previous users. But how to scale such systems with a growing database of user interactions? The first proposed approach involves clustering of Dialogue Systems (tailored for their respective user) based on their behaviours. We demonstrated through handcrafted and real user-models experiments how this method improves the dialogue quality for new and unknown users. The second approach extends the Deep Q-learning algorithm with a continuous transfer process. The second idea states that before using a dedicated Dialogue System, the first in- teractions with a user should be handled carefully by a safe Dialogue System common to all users. The underlying approach is divided in two steps. The first step consists in learning a safe strategy through Reinforcement Learning. To that extent, we introduced a budgeted Reinforcement Learning framework for continuous state space and the underlying extensions of classic Reinforcement Learning algorithms. In particular, the safe version of the Fitted-Q algorithm has been validated, in term of safety and efficiency, on a dialogue system tasks and an autonomous driving problem. The second step consists in using those safe strategies when facing new users; this method is an extension of the classic ε-greedy algorithm.
Les systèmes d’intelligence artificielle les plus puissants utilisent désormais des modèles statistiques. Afin de construire des modèles efficaces, ces systèmes doivent collecter une quantité substantielle de données issues de l’environnement. Les assistants personnels, maisons connectées, serveurs vocaux et autres systèmes de dialogue ne font pas exception. Ces systèmes ont pour vocation d’interagir avec des humains, et pour cela, leurs données d’apprentissage se doivent d’être collectées avec ces mêmes humains. Parce que le nombre d’interactions avec une seule personne est assez faible, l’approche usuelle pour augmenter le jeu de données consiste à agréger les données de tous les utilisateurs. Une des limitations de cette approche vient du fait que, par construction, les mod- èles entraînés ainsi ne sont efficaces qu’avec un humain "moyen" et n’incluent pas de système d’adaptation ; cette faiblesse entraîne la restriction du service à certains groupes de personnes; Par conséquent, cela réduit l’ensemble des utilisateurs et provoque des problèmes d’inclusion. La présente thèse propose des solutions impliquant la construction de systèmes de dialogue combinant l’apprentissage par transfert et l’apprentissage par renforcement. La thèse explore deux pistes de recherche : La première consiste à inclure un mécanisme d’adaptation dès les premières interac- tions avec un nouvel utilisateur. Pour ce faire, nous utilisons la connaissance accumulée avec des utilisateurs déjà connus du système. La question sous-jacente est la suivante : comment gérer l’évolution du système suite à une croissance interrompue d’utilisateurs et donc de connaissance? La première approche implique le clustering des systèmes de dialogue (chacun étant spécialisé pour un utilisateur) en fonction de leurs stratégies. Nous démontrons que la méthode améliore la qualité des dialogues en interagissant avec des modèles à base de règles et des modèles d’humains. La seconde approche propose d’inclure un mécanisme d’apprentissage par transfert dans l’exécution d’un algorithme d’apprentissage profond par renforcement, Deep Q-learning. La seconde piste avance l’idée selon laquelle les premières interactions avec un nouvel utilisateur devraient être gérées par un système de dialogue sécurisé et précautionneux avant d’utiliser un système de dialogue spécialisé. L’approche se divise en deux étapes. La première étape consiste à apprendre une stratégie sécurisée avec de l’apprentissage par renforcement. À cet effet, nous proposons un nouveau framework d’apprentissage par renforcement sous contrainte en états continus ainsi que des algorithmes les solutionnant. En particulier, nous validons, en termes de sécurité et d’efficacité, une extension de Fitted- Q pour les deux applications sous contraintes : les systèmes de dialogue et la conduite autonome. La deuxième étape implique l’utilisation de ces stratégies sécurisées lors des premières interactions avec un nouvel utilisateur ; cette méthode est une extension de l’algorithme classique d’exploration, ε-greedy
thesis-nicolas-carrara.pdf (2.26 Mo) Télécharger le fichier
tel-02422691 , version 1 (23-12-2019)
  • HAL Id : tel-02422691 , version 1
Nicolas Carrara. Reinforcement learning for Dialogue Systems optimization with user adaptation.. Artificial Intelligence [cs.AI]. Ecole Doctoral Science pour l'Ingénieur Université Lille Nord-de-France, 2019. English. ⟨NNT : ⟩. ⟨tel-02422691⟩
1263 Consultations
1078 Téléchargements
