Analyse d’incertitudes et de robustesse pour les modèles à entrées et sorties fonctionnelles. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Uncertainty and robustness analysis for models with functional inputs and outputs.
This thesis deals with the inversion problem under uncertainty of expensive-to-evaluate functions in the context of the tuning of the control unit of a vehicule depollution system. The effect of these uncertainties is taken into account through the expectation of the quantity of interest. The problem lies in the fact that the uncertainty is partly due to a functional variable only known through a given sample. We propose two approaches to solve the inversion problem, both methods are based on Gaussian Process modelling for expensive-to-evaluate functions and a dimension reduction of the functional variable by the Karhunen-Loève expansion. The first methodology consists in applying a Stepwise Uncertainty Reduction (SUR) method on the expectation of the quantity of interest. At each evaluation point in the control space, the expectation is estimated by a greedy functional quantification method that provides a discrete representation of the functional variable and an effective sequential estimate from the given sample. The second approach consists in applying the SUR method directly to the quantity of interest in the joint space. Devoted to inversion under functional uncertainties, a strategy for enriching the experimental design exploiting the properties of Gaussian processes is proposed. These two approaches are compared on toy analytical examples and are applied to an industrial application for an exhaust gas post-treatment system of a vehicle. The objective is to identify the set of control parameters that leads to meet the pollutant emission norms under uncertainties on the driving cycle.
L'objectif de cette thèse est de résoudre un problème d'inversion sous incertitudes de fonctions coûteuses à évaluer dans le cadre du paramétrage du contrôle d'un système de dépollution de véhicules. L'effet de ces incertitudes est pris en compte au travers de l'espérance de la grandeur d'intérêt. Une difficulté réside dans le fait que l'incertitude est en partie due à une entrée fonctionnelle connue à travers d'un échantillon donné. Nous proposons deux approches basées sur une approximation du code coûteux par processus gaussiens et une réduction de dimension de la variable fonctionnelle par une méthode de Karhunen-Loève. La première approche consiste à appliquer une méthode d'inversion de type SUR (Stepwise Uncertainty Reduction) sur l'espérance de la grandeur d'intérêt. En chaque point d'évaluation dans l'espace de contrôle, l'espérance est estimée par une méthode de quantification fonctionnelle gloutonne qui fournit une représentation discrète de la variable fonctionnelle et une estimation séquentielle efficace à partir de l'échantillon donné de la variable fonctionnelle. La deuxième approche consiste à appliquer la méthode SUR directement sur la grandeur d'intérêt dans l'espace joint des variables de contrôle et des variables incertaines. Une stratégie d'enrichissement du plan d'expériences dédiée à l'inversion sous incertitudes fonctionnelles et exploitant les propriétés des processus gaussiens est proposée. Ces deux approches sont comparées sur des fonctions jouets et sont appliquées à un cas industriel de post-traitement des gaz d'échappement d'un véhicule. La problématique est de déterminer les réglages du contrôle du système permettant le respect des normes de dépollution en présence d'incertitudes, sur le cycle de conduite.
Mnscrt_These.pdf (2.65 Mo) Télécharger le fichier
tel-02433324 , version 1 (09-01-2020)
  • HAL Id : tel-02433324 , version 1
Mohamed Reda El Amri. Analyse d’incertitudes et de robustesse pour les modèles à entrées et sorties fonctionnelles.. Mathématiques [math]. Université Grenoble Alpes, 2019. Français. ⟨NNT : ⟩. ⟨tel-02433324⟩
328 Consultations
407 Téléchargements
