Mixtures of Gaussian Graphical Models with Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Mélanges de modèles graphiques gaussiens sous contraintes
Describing the co-variations between several observed random variables is a delicate problem. Dependency networks are popular tools that depict the relations between variables through the presence or absence of edges between the nodes of a graph. In particular, conditional correlation graphs are used to represent the “direct” correlations between nodes of the graph. They are often studied under the Gaussian assumption and consequently referred to as “Gaussian Graphical Models” (GGM). A single network can be used to represent the overall tendencies identified within a data sample. However, when the observed data is sampled from a heterogeneous population, then there exist different sub-populations that all need to be described through their own graphs. What is more, if the sub-population (or “class”) labels are not available, unsupervised approaches must be implemented in order to correctly identify the classes and describe each of them with its own graph. In this work, we tackle the fairly new problem of Hierarchical GGM estimation for unlabelled heterogeneous populations. We explore several key axes to improve the estimation of the model parameters as well as the unsupervised identification of the sub-populations. Our goal is to ensure that the inferred conditional correlation graphs are as relevant and interpretable as possible. First - in the simple, homogeneous population case - we develop a composite method that combines the strengths of the two main state of the art paradigms to correct their weaknesses. For the unlabelled heterogeneous case, we propose to estimate a Mixture of GGM with an Expectation Maximisation (EM) algorithm. In order to improve the solutions of this EM algorithm, and avoid falling for sub-optimal local extrema in high dimension, we introduce a tempered version of this EM algorithm, that we study theoretically and empirically. Finally, we improve the clustering of the EM by taking into consideration the effect of external co-features on the position in space of the observed data.
La description des co-variations entre plusieurs variables aléatoires observées est un problème délicat. Les réseaux de dépendance sont des outils populaires qui décrivent les relations entre les variables par la présence ou l’absence d’arêtes entre les nœuds d’un graphe. En particulier, les graphes de corrélations conditionnelles sont utilisés pour représenter les corrélations “directes” entre les nœuds du graphe. Ils sont souvent étudiés sous l’hypothèse gaussienne et sont donc appelés “modèles graphiques gaussiens” (GGM). Un seul réseau peut être utilisé pour représenter les tendances globales identifiées dans un échantillon de données. Toutefois, lorsque les données observées sont échantillonnées à partir d’une population hétérogène, il existe alors différentes sous-populations qui doivent toutes être décrites par leurs propres graphes. De plus, si les labels des sous populations (ou “classes”) ne sont pas disponibles, des approches non supervisées doivent être mises en œuvre afin d’identifier correctement les classes et de décrire chacune d’entre elles avec son propre graphe. Dans ce travail, nous abordons le problème relativement nouveau de l’estimation hiérarchique des GGM pour des populations hétérogènes non labellisées. Nous explorons plusieurs axes clés pour améliorer l’estimation des paramètres du modèle ainsi que l’identification non supervisee des sous-populations. ´ Notre objectif est de s’assurer que les graphes de corrélations conditionnelles inférés sont aussi pertinents et interprétables que possible. Premièrement - dans le cas d’une population simple et homogène - nous développons une méthode composite qui combine les forces des deux principaux paradigmes de l’état de l’art afin d’en corriger les faiblesses. Pour le cas hétérogène non labellisé, nous proposons d’estimer un mélange de GGM avec un algorithme espérance-maximisation (EM). Afin d’améliorer les solutions de cet algorithme EM, et d’éviter de tomber dans des extrema locaux sous-optimaux quand les données sont en grande dimension, nous introduisons une version tempérée de cet algorithme EM, que nous étudions théoriquement et empiriquement. Enfin, nous améliorons le clustering de l’EM en prenant en compte l’effet que des cofacteurs externes peuvent avoir sur la position des données observées dans leur espace.
95237_LARTIGUE_2020_archivage.pdf (24.92 Mo) Télécharger le fichier
tel-02981007 , version 1 (27-10-2020)
  • HAL Id : tel-02981007 , version 1
Thomas Lartigue. Mixtures of Gaussian Graphical Models with Constraints. Statistics [math.ST]. Institut Polytechnique de Paris, 2020. English. ⟨NNT : 2020IPPAX034⟩. ⟨tel-02981007⟩
440 Consultations
73 Téléchargements
