Yaʿqûb Ṣannûʿ, du théâtre au journalisme : L’écriture théâtrale dans Abû Naẓẓâra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Writing and Literary Strategies in the Satirical Arab Press during the Nahda : Abû Naẓẓāra Zarqā’ of Ya͑qūb Ṣannū ͑
Yaʿqûb Ṣannûʿ (1839-1912) is a controversial author of the Nahḍa and one of the pioneers of Arabic theatreand journalism. This thesis, based on the first years of Ṣannûʿ's magazine, Abû Naẓẓâra (1878-1910),intends to analyze that interplay between dramatic writing and journalistic writing. The first has a bridgingfunction leading to the second that emerges from the interactions between the Arabic literary heritage andthe 19 th century European press. Ṣannuʿ draws inspiration from the ancient Arabic theatrical forms inorder to write "dramatic journalistic" stage plays that capture the news. Furthermore, in Abû Naẓẓâra, thedialogue becomes an autonomous genre in itself as well as the main news-making means. Therefore, onemust consider that the whole magazine builds up on the model of the play. Dramatic writing serves thejournalistic purpose: theater takes part in the dynamics of satire while the dialogue takes on a didactic rolefor the press readers. Abû Naẓẓâra claims to be the voice of the Egyptians. Politics is perceived throughtheatrical metaphor and depicted as a farce. The play, initially intended to be read and performedcollectively, turns the reader into an actor of the political stage.
Yaʿqûb Ṣannûʿ(1839-1912), auteur polémique de la Nahḍa, est un des pionniers du théâtre et dujournalisme arabes. La thèse se propose d’analyser, à partir des premières années de son journal AbûNaẓẓâra (1878-1910), la relation entre écriture théâtrale et écriture journalistique, l’une servant de relaisvers la seconde qui s’invente entre le patrimoine littéraire arabe et la presse européenne du XIXème siècle.Ṣannûʿ s’inspire de formes théâtrales arabes anciennes pour créer des pièces « théatro-journalistiques »qui s’emparent de l’actualité. Par ailleurs, dans Abû Naẓẓâra, le dialogue s’affirme comme genre autonomeet mode principal de traitement de l’actualité. Dès lors, on doit considérer que l’ensemble du journal seconstruit sur le modèle du texte théâtral. L’écriture dramatique est mise au service du projetjournalistique : le théâtre participe de la dynamique satirique tandis que le dialogue a une visée didactiqueen direction du lecteur de la presse. Abû Naẓẓâra prétend se faire le porte-parole du peuple égyptien. Lepolitique y est approché à travers le prisme de la métaphore théâtrale et présenté comme une grandecomédie. La pièce de théâtre, conçue pour être lue collectivement et jouée, fait du lecteur un acteur de lascène politique.
Arroues_Ophelie_va.pdf (12.36 Mo) Télécharger le fichier
tel-03064634 , version 1 (14-12-2020)
  • HAL Id : tel-03064634 , version 1
Ophélie Arroues Ben Selma. Yaʿqûb Ṣannûʿ, du théâtre au journalisme : L’écriture théâtrale dans Abû Naẓẓâra. Littératures. Université Sorbonne Paris Cité, 2018. Français. ⟨NNT : 2018USPCF022⟩. ⟨tel-03064634⟩
234 Consultations
156 Téléchargements
