Deep generative models : over-generalisation and mode-dropping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Modèles génératifs profonds : sur-généralisation et abandon de mode
This dissertation explores the topic of generative modelling of natural images,which is the task of fitting a data generating distribution.Such models can be used to generate artificial data resembling the true data, or to compress images.Latent variable models, which are at the core of our contributions, seek to capture the main factors of variations of an image into a variable that can be manipulated.In particular we build on two successful latent variable generative models, the generative adversarial network (GAN) and Variational autoencoder (VAE) models.Recently GANs significantly improved the quality of images generated by deep models, obtaining very compelling samples.Unfortunately these models struggle to capture all the modes of the original distribution, ie they do not cover the full variability of the dataset.Conversely, likelihood based models such as VAEs typically cover the full variety of the data well and provide an objective measure of coverage.However these models produce samples of inferior visual quality that are more easily distinguished from real ones.The work presented in this thesis strives for the best of both worlds: to obtain compelling samples while modelling the full support of the distribution.To achieve that, we focus on i) the optimisation problems used and ii) practical model limitations that hinder performance.The first contribution of this manuscript is a deep generative model that encodes global image structure into latent variables, built on the VAE, and autoregressively models low level detail.We propose a training procedure relying on an auxiliary loss function to control what information is captured by the latent variables and what information is left to an autoregressive decoder.Unlike previous approaches to such hybrid models, ours does not need to restrict the capacity of the autoregressive decoder to prevent degenerate models that ignore the latent variables.The second contribution builds on the standard GAN model, which trains a discriminator network to provide feedback to a generative network.The discriminator usually assesses the quality of individual samples, which makes it hard to evaluate the variability of the data.Instead we propose to feed the discriminator with emph{batches} that mix both true and fake samples, and train it to predict the ratio of true samples in the batch.These batches work as approximations of the distribution of generated images and allows the discriminator to approximate distributional statistics.We introduce an architecture that is well suited to solve this problem efficiently,and show experimentally that our approach reduces mode collapse in GANs on two synthetic datasets, and obtains good results on the CIFAR10 and CelebA datasets.The mutual shortcomings of VAEs and GANs can in principle be addressed by training hybrid models that use both types of objective.In our third contribution, we show that usual parametric assumptions made in VAEs induce a conflict between them, leading to lackluster performance of hybrid models.We propose a solution based on deep invertible transformations, that trains a feature space in which usual assumptions can be made without harm.Our approach provides likelihood computations in image space while being able to take advantage of adversarial training.It obtains GAN-like samples that are competitive with fully adversarial models while improving likelihood scores over existing hybrid models at the time of publication, which is a significant advancement.
Cette dissertation explore le sujet des modèles génératifs appliqués aux images naturelles.Cette tâche consiste a modéliser la distribution des données observées, et peut permettre de générer des données artificielles semblables aux données d'origine, où de compresser des images.Les modèles à variable latentes, qui sont au cœur de cette thèse, cherchent a résumer les principaux facteurs de variation d'une image en une variable qui peut être manipulée.En particulier, nos contributions sont basées sur deux modèles génératifs a variable latentes: le modèle génératif adversarial (GAN) et l' encodeur variationel (VAE).Récemment, les GAN ont significativement amélioré la qualité des images générées par des modèles profonds, générant des images très convaincantes.Malheureusement ces modèles ont du mal à modéliser tous les modes de la distribution d'origine, ie ils ne couvrent pas les données dans toute leur variabilité.A l'inverse, les modèles basés sur le maximum de vraisemblance tels que les VAEs couvrent typiquement toute la variabilité des données, et en offrent une mesure objective.Mais ces modèles produisent des échantillons de qualité visuelle inférieure, qui sont plus facilement distingués de vrais images.Le travail présenté dans cette thèse a pour but d'obtenir le meilleur des deux mondes: des échantillons de bonne qualité tout en modélisant tout le support de la distribution.La première contribution de ce manuscrit est un modèle génératif profond qui encode la structure globale des images dans une variable latente, basé sur le VAE, et utilise un modèle autoregressif pour modéliser les détails de bas niveau.Nous proposons une procédure d'entrainement qui utilise une fonction de perte auxiliaire pour contrôler quelle information est capturée par la variable latent et quelle information est laissée à un décodeur autoregressif.Au contraire des précédentes approches pour construire des modèles hybrides de ce genre, notre modèle de nécessite pas de contraindre la capacité du décodeur autoregressif pour empêcher des modèles dégénérés qui ignorent la variable latente.La deuxième contribution est bâtie sur le modèle du GAN standard, qui utilise un discriminateur pour guider le modèle génératif.Le discriminateur évalue généralement la qualité d'échantillons individuels, ce qui rend la tache d'évaluer la variabilité des données difficile.A la place, nous proposons de fournir au discriminateur des ensembles de données, ou batches, qui mélangent des vraies images et des images générées.Nous l'entrainons à prédire le ratio de vrais et de faux éléments dans l'ensemble.Ces batches servent d'approximation de la vrai distribution des images générées et permettent au discriminateur d'approximer des statistiques sur leur distributionLes lacunes mutuelles des VAEs et des GANs peuvent, en principe, être réglées en entrainant des modèles hybrides qui utilisent les deux types d'objectif.Dans notre troisième contribution, nous montrons que les hypothèses paramétriques habituelles faites par les VAE produisent un conflit entre les deux, menant à des performances décevantes pour les modèles hybrides.Nous proposons une solution basée sur des modèles profonds inversibles, qui entraine un espace de features dans lequel les hypothèses habituelles peuvent être faites sans poser problème.Notre approche fourni des évaluations e vraisemblance dans l'espace des images tout en étant capable de tirer profit de l'entrainement adversaire.Elle obtient des échantillons de qualité équivalente au modèle pleinement adversaires tout en améliorant les scores de maximum de vraisemblance au moment de la publication, ce qui constitue une amélioration significative.
LUCAS_2020_archivage.pdf (47.44 Mo) Télécharger le fichier
tel-03102554 , version 1 (07-01-2021)
  • HAL Id : tel-03102554 , version 1
Thomas Lucas. Deep generative models : over-generalisation and mode-dropping. Artificial Intelligence [cs.AI]. Université Grenoble Alpes [2020-..], 2020. English. ⟨NNT : 2020GRALM049⟩. ⟨tel-03102554⟩
446 Consultations
150 Téléchargements
