Approches d'apprentissage profond pour la détection en couche physique de télécommunications multi-accès - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2021
Deep learning based approaches for detection in physical layer wireless multiple access
Current trends point towards an accelerated augmentation of devices with a desire to access the shared radio spectrum, both due to the continued democratisation and capability augmentation of user facing radio devices, such as cellphones, computers, and especially wearables, but also to the deployment of connected objects and sensors. Technology, protocols, and legislation improvements increase the available frequency bands by opening new channels in the GHz range, but the density of devices is nevertheless expected to increase. Multiple access to a shared radio frequency resource leads to situations that are both complex to model, and to tackle with known algorithms, and it is true of detection tasks that arise in the physical layer of a wireless transmission. The class of deep learning algorithms is especially useful in this sort of situation without model, or with non tractable algorithms, as long as a large amount of labelled data is available to train the related neural networks. This thesis aims at adapting the deep learning tool to physical layer detection problems, in successive steps of a decoding chain. First with the problem of detecting the origin of a received packet, starting with hardware fingerprinting of a transmitting device, and extending it to a scenario with multiple active devices at the same time, detecting the set of active devices transmitting an explicit codeword. The next step after origin detection is bit detection, to decode transmitted messages. For that, deep learning is used to learn constellations allowing for an efficient bit detection in a multiple-access scenario, namely the two-user uplink NOMA. Data used to train the networks involved in this thesis are gathered both from simulated models, and from experimental implementations in the FIT CorteXlab software defined radio test-bed.
Les tendances actuelles pointent vers une accélération de l'augmentation du nombre d'objets cherchant à accéder au spectre radio, à la fois par la démocratisation des objets grand public, smartphones, ordinateurs, montres connectées,... et par le déploiement d'objets et capteurs connectés. Des avancées technologiques, protocolaires et législatives augmentent les bandes de fréquence disponibles en ouvrant l'accès à la zone des GHz, mais la densité des objets communicant sur le spectre tend quand même à augmenter. L'accès multiple à une ressource radio partagée mène à des situations qui sont à la fois complexes à modéliser et à aborder avec les algorithmes actuels, et c'est particulièrement vrai pour les taches de type détection présentes au niveau des couches physiques des communications sans fil. Les algorithmes d'apprentissage profond sont particulièrement utiles dans ce type de situation, sans modèle ou avec des algorithmes existant peu pratiques, pour peu qu'une grande quantité de données soit disponible pour entraîner les réseaux de neurones. Cette thèse vise à adapter l'outil de l'apprentissage profond aux problèmes de détection de la couche physique, à différentes étapes de la chaîne de décodage. D'abord par le problème de la détection d'origine d'un paquet reçu, commençant par l'identification de caractéristiques matérielles d'un l'objet émetteur, puis étendant ce scénario à un ensemble d'objets actifs simultanément. L'étape suivant la détection de l'origine d'un paquet est la détection des bits, pour décoder les messages transmis. Dans ce cadre, l'apprentissage profond est employé pour apprendre des constellations permettant une détection efficace des bits dans un scénario multi-accès non orthogonal à deux utilisateurs. Les données servant à l'apprentissage des réseaux de neurones impliqués dans cette thèse sont récoltées soit dans des modèles simulés, soit par des expériences implémentées dans l'équipement de radio logicielle FIT CorteXlab.
these.pdf (9.77 Mo) Télécharger le fichier
tel-03470004 , version 1 (08-12-2021)
  • HAL Id : tel-03470004 , version 1
Cyrille Morin. Approches d'apprentissage profond pour la détection en couche physique de télécommunications multi-accès. Traitement du signal et de l'image [eess.SP]. Université de Lyon, 2021. Français. ⟨NNT : 2021LYSEI049⟩. ⟨tel-03470004⟩
271 Consultations
253 Téléchargements
