Online learning for network resource allocation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2022
Apprentissage séquentiel pour l'allocation de ressources dans les réseaux
Network resource allocation is a complex and fundamental problem in computer science. It is a process in which components of a networked system aim to provide a faster service to demands, or to reduce the computation or communication load on the system. The main factors that contribute to the complexity of this problem are that the demands arrive to the system in an unpredictable and sequential fashion and may compete for the different network resources. The ubiquity of network resource allocation problems has motivated extensive research to design new policies with provable guarantees. This thesis investigates several instances of the network resource allocation problem and proposes online policies with strong performance guarantees leveraging the online learning framework.First, we study the online caching problem in which demands for files can be served by a local cache to avoid retrieval costs from a remote server. We study no-regret algorithms based on online mirror descent (OMD) strategies. We show that the optimal OMD strategy depends on the request diversity present in a batch of demands. We also prove that, when the cache must store the entire file, rather than a fraction, OMD strategies can be coupled with a randomized rounding scheme that preserves regret guarantees. We also present an extension to cache networks, and we propose a no-regret distributed online policy.Second, we investigate similarity caches that can reply to a demand for an object with similar objects stored locally. We propose a new online similarity caching policy that employs gradient descent to navigate the continuous representation space of objects and find appropriate objects to store in the cache. We provide theoretical convergence guarantees under stationary demands and show the proposed policy reduces service costs incurred by the system for 360-video delivery systems and recommendation systems. Subsequently, we show that the similarity caching problem can be formulated in the online learning framework by utilizing an OMD policy paired with randomized rounding to achieve a no-regret guarantee.Third, we present the novel idea of inference delivery networks (IDNs), networks of computing nodes that coordinate to satisfy machine learning (ML) inference demands achieving the best trade-off between latency and accuracy. IDNs bridge the dichotomy between device and cloud execution by integrating inference delivery at the various tiers of the infrastructure continuum (access, edge, regional data center, cloud). We propose a no-regret distributed dynamic policy for ML model allocation in an IDN: each node dynamically updates its local set of inference models based on demands observed during the recent past plus limited information exchange with its neighboring nodes.Finally, we study the fairness of network resource allocation problem under the alpha-fairness criterion. We recognize two different fairness objectives that naturally arise in this problem: the well-understood slot-fairness objective that aims to ensure fairness at every timeslot, and the less explored horizon-fairness objective that aims to ensure fairness across utilities accumulated over a time horizon. We argue that horizon-fairness comes at a lower price in terms of social welfare. We study horizon-fairness with the regret as a performance metric and show that vanishing regret cannot be achieved in presence of an unrestricted adversary. We propose restrictions on the adversary's capabilities corresponding to realistic scenarios and an online policy that indeed guarantees vanishing regret under these restrictions. We demonstrate the applicability of the proposed fairness framework to a representative resource management problem considering a virtualized caching system where different caches cooperate to serve content requests.
L'allocation de ressources dans les réseaux est un problème complexe et fondamental en informatique. Il s'agit d'un processus dans lequel les composants d'un système de réseau visent à fournir un service plus rapide aux demandes ou à réduire la charge de calcul ou de communication sur le système. Les principaux facteurs qui contribuent à la complexité de ce problème sont que les demandes arrivent au système de manière imprévisible et séquentielle et peuvent entrer en concurrence pour les différentes ressources du réseau. L'ubiquité des problèmes d'allocation de ressources dans les réseaux a motivé des recherches approfondies pour concevoir de nouveaux algorithmes avec des garanties prouvables. Cette thèse étudie plusieurs instances du problème d'allocation de ressources dans les réseaux et propose des algorithmes adaptatifs avec de fortes garanties de performances s'appuyant sur le cadre d'apprentissage séquentiel.Premièrement, nous étudions le problème de mise en cache séquentiel, dans lequel les demandes de fichiers peuvent être servies par un cache local pour éviter les coûts de récupération à partir d'un serveur distant. Nous étudions des algorithmes avec des garanties de performance basés sur des stratégies de descente miroir (DM). Nous montrons que la stratégie DM optimale dépend de la diversité présente dans un lot de demandes. Nous prouvons également que, lorsque le cache doit stocker le fichier entier, plutôt qu'une fraction, les stratégies DM peuvent être couplées à un schéma d'arrondi aléatoire qui préserve garanties de performance. Nous présentons de plus une extension aux réseaux de caches, et nous proposons un algorithme adaptatif distribué. Deuxièmement, nous étudions les caches de similarité qui peuvent répondre à une demande d'un objet avec des objets similaires stockés localement. Nous proposons un nouvel algorithme de mise en cache de similarité séquentiel qui utilise la descente de gradient pour naviguer dans l'espace de représentation continue des objets et trouver les objets appropriés à stocker dans le cache. Nous montrons que l'algorithme proposé réduit les coûts de service encourus par le système pour les systèmes de diffusion vidéo à 360 degrés et les systèmes de recommandation. Par la suite, nous montrons que le problème de mise en cache de similarité peut être formulé dans le cadre d'apprentissage séquentiel en utilisant un algorithme MD associée à un arrondi aléatoire.Troisièmement, nous présentons les réseaux de distribution d'inférence (RDI) émergents, des réseaux de nœuds informatiques qui se coordonnent pour satisfaire les demandes d'inférence d'apprentissage automatique (AA) en obtenant le meilleur compromis entre latence et précision. Nous proposons un algorithme adaptatif distribué pour l'allocation de modèles d'AA dans un RDI : chaque nœud met à jour dynamiquement son ensemble local de modèles d'inférence en fonction des demandes observées au cours du passé récent et d'un échange d'informations limité avec ses nœuds voisins. Finalement, nous étudions l'équité du problème d'allocation des ressources réseau sous le critère d'alpha-fairness. Nous reconnaissons deux objectifs d'équité différents qui surgissent naturellement dans ce problème : l'objectif d'équité de tranche bien compris qui vise à assurer l'équité à chaque tranche de temps, et l'objectif d'équité d'horizon moins exploré qui vise à assurer l'équité entre les utilités accumulées sur un horizon temporel. Nous étudions l'équité de l'horizon avec le regret comme métrique de performance et montrons que la disparition du regret ne peut être atteinte en présence d'un adversaire sans restriction. Nous proposons des restrictions sur les capacités de l'adversaire correspondant à des scénarios réalistes et un algorithme adaptatif qui garantit en effet la disparition du regret sous ces restrictions.
2022COAZ4055.pdf (16.97 Mo) Télécharger le fichier
tel-03885484 , version 1 (05-12-2022)
  • HAL Id : tel-03885484 , version 1
Tareq Si Salem. Online learning for network resource allocation. Networking and Internet Architecture [cs.NI]. Université Côte d'Azur, 2022. English. ⟨NNT : 2022COAZ4055⟩. ⟨tel-03885484⟩
148 Consultations
160 Téléchargements
