Hardware accelerated simulation and automatic design of heterogeneous architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Simulation accélérée par matériel et conception automatique d’architectures hétérogènes
The design of heterogeneous system-on-chip platforms is complex with many possible combinations. Detailed simulation of different solutions is necessary to determine the best design. Existing simulation environments (such as gem5) are limited as they are purely software based and do not take into account heterogeneous architectures. To address these limitations, the use of reprogrammable FPGA components to accelerate simulation is motivated. Our work is divided into two parts. The first part is experimental and studied an approach to design heterogeneous architectures focusing on simulating performance models of architecture components (hardware accelerators and processor cores) on FPGA. The second part is methodological and concerns a flow to determine the best microarchitecture in terms of performance to energy consumption ratio. This flow combines a software architecture simulator and a hyperparameter optimization method to find the best combination of parallelism, loop unrolling strategies, and memory interfaces. Experiments were conducted on different problems to determine the most optimal solutions in terms of energy efficiency.
La conception de plates-formes de système sur puce hétérogènes est complexe avec de nombreuses combinaisons possibles. La simulation détaillée de différentes solutions est nécessaire pour déterminer le meilleur design. Les environnements de simulation existants (tels que gem5) sont limités car purement logiciels et ne prennent pas en compte les architectures hétérogènes. Pour pallier ces limitations, l'utilisation de composants reprogrammables FPGA pour accélérer la simulation est motivée. Notre travail est divisé en deux parties. La première partie est d'ordre expérimental et a étudié une approche de conception d'architectures hétérogènes en se concentrant sur la simulation de modèles de performance de composants de l'architecture (accélérateurs matériels et cœurs de processeurs) sur FPGA. La seconde partie est méthodologique et concerne un flot pour déterminer la meilleure microarchitecture en termes de rapport performance/consommation d'énergie. Ce flot combine un simulateur logiciel d'architecture et une méthode d'optimisation d'hyperparamètres pour trouver la meilleure combinaison de parallélisme, stratégies de déroulage de boucles et interfaces de mémoire. Les expérimentations ont été menées sur différents problèmes pour déterminer les solutions les plus optimales en termes d'efficacité énergétique.
CONG_Minh_Thanh.pdf (6.01 Mo) Télécharger le fichier
tel-04136213 , version 1 (21-06-2023)
  • HAL Id : tel-04136213 , version 1
Minh Thanh Cong. Hardware accelerated simulation and automatic design of heterogeneous architecture. Hardware Architecture [cs.AR]. Université de Rennes, 2023. English. ⟨NNT : 2023URENS002⟩. ⟨tel-04136213⟩
97 Consultations
75 Téléchargements
