Deciphering the neural bases of language comprehension using latent linguistic representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Déchiffrer les bases neurales de la compréhension du langage à l'aide de représentations linguistiques latentes
In the last decades, language models (LMs) have reached human level performance on several tasks. They can generate rich representations (features) that capture various linguistic properties such has semantics or syntax. Following these improvements, neuroscientists have increasingly used them to explore the neural bases of language comprehension. Specifically, LM's features computed from a story are used to fit the brain data of humans listening to the same story, allowing the examination of multiple levels of language processing in the brain. If LM's features closely align with a specific brain region, then it suggests that both the model and the region are encoding the same information. LM-brain comparisons can then teach us about language processing in the brain. Using the fMRI brain data of fifty US participants listening to "The Little Prince" story, this thesis 1) investigates the reasons why LMs' features fit brain activity and 2) examines the limitations of such comparisons. The comparison of several pre-trained and custom-trained LMs (GloVe, LSTM, GPT-2 and BERT) revealed that Transformers better fit fMRI brain data than LSTM and GloVe. Yet, none are able to explain all the fMRI signal, suggesting either limitations related to the encoding paradigm or to the LMs. Focusing specifically on Transformers, we found that no brain region is better fitted by specific attentional head or layer. Our results caution that the nature and the amount of training data greatly affects the outcome, indicating that using off-the-shelf models trained on small datasets is not effective in capturing brain activations. We showed that LMs' training influences their ability to fit fMRI brain data, and that perplexity was not a good predictor of brain score. Still, training LMs particularly improves their fitting performance in core semantic regions, irrespective of the architecture and training data. Moreover, we showed a partial convergence between brain's and LM's representations.Specifically, they first converge during model training before diverging from one another. This thesis further investigates the neural bases of syntax, semantics and context-sensitivity by developing a method that can probe specific linguistic dimensions. This method makes use of "information-restricted LMs", that are customized LMs architectures trained on feature spaces containing a specific type of information, in order to fit brain data. First, training LMs on semantic and syntactic features revealed a good fitting performance in a widespread network, albeit with varying relative degrees. The quantification of this relative sensitivity to syntax and semantics showed that brain regions most attuned to syntax tend to be more localized, while semantic processing remain widely distributed over the cortex. One notable finding from this analysis was that the extent of semantic and syntactic sensitive brain regions was similar across hemispheres. However, the left hemisphere had a greater tendency to distinguish between syntactic and semantic processing compared to the right hemisphere. In a last set of experiments we designed "masked-attention generation", a method that controls the attention mechanisms in transformers, in order to generate latent representations that leverage fixed-size context. This approach provides evidence of context-sensitivity across most of the cortex. Moreover, this analysis found that the left and right hemispheres tend to process shorter and longer contextual information respectively.
Au cours des dernières décennies, les modèles de langage (MLs) ont atteint des performances équivalentes à celles de l'homme sur plusieurs tâches. Ces modèles peuvent générer des représentations vectorielles qui capturent diverses propriétés linguistiques des mots d'un texte, telles que la sémantique ou la syntaxe. Les neuroscientifiques ont donc mis à profit ces progrès et ont commencé à utiliser ces modèles pour explorer les bases neurales de la compréhension du langage. Plus précisément, les représentations des ML calculées à partir d'une histoire sont utilisées pour modéliser les données cérébrales d'humains écoutant la même histoire, ce qui permet l'examen de plusieurs niveaux de traitement du langage dans le cerveau. Si les représentations du ML s'alignent étroitement avec une région cérébrale, il est probable que le modèle et la région codent la même information. En utilisant les données cérébrales d'IRMf de participants américains écoutant l'histoire du Petit Prince, cette thèse 1) examine les facteurs influant l'alignement entre les représentations des MLs et celles du cerveau, ainsi que 2) les limites de telles alignements. La comparaison de plusieurs MLs pré-entraînés et personnalisés (GloVe, LSTM, GPT-2 et BERT) a révélé que les Transformers s'alignent mieux aux données d'IRMf que LSTM et GloVe. Cependant, aucun d'entre eux n'est capable d'expliquer tout le signal IRMf, suggérant des limites liées au paradigme d'encodage ou aux MLs. En étudiant l'architecture des Transformers, nous avons constaté qu'aucune région cérébrale n'est mieux expliquée par une couche ou une tête d'attention spécifique. Nos résultats montrent que la nature et la quantité de données d'entraînement affectent l'alignement. Ainsi, les modèles pré-entraînés sur de petits ensembles de données ne sont pas efficaces pour capturer les activations cérébrales. Nous avons aussi montré que l'entraînement des MLs influence leur capacité à s'aligner aux données IRMf et que la perplexité n'est pas un bon prédicteur de leur capacité à s'aligner. Cependant, entraîner les MLs améliore particulièrement leur performance d'alignement dans les régions coeur de la sémantique, indépendamment de l'architecture et des données d'entraînement. Nous avons également montré que les représentations du cerveau et des MLs convergent d'abord pendant l'entraînement du modèle avant de diverger l'une de l'autre. Cette thèse examine en outre les bases neurales de la syntaxe, de la sémantique et de la sensibilité au contexte en développant une méthode qui peut sonder des dimensions linguistiques spécifiques. Cette méthode utilise des MLs restreints en information, c'est-à-dire des architectures entraînées sur des espaces de représentations contenant un type spécifique d'information. Tout d'abord, l'entraînement de MLs sur des représentations sémantiques et syntaxiques a révélé un bon alignement dans la plupart du cortex mais avec des degrés relatifs variables. La quantification de cette sensibilité relative à la syntaxe et à la sémantique a montré que les régions cérébrales les plus sensibles à la syntaxe sont plus localisées, contrairement au traitement de la sémantique qui reste largement distribué dans le cortex. Une découverte notable de cette thèse est que l'étendue des régions cérébrales sensibles à la syntaxe et à la sémantique est similaire dans les deux hémisphères. Cependant, l'hémisphère gauche a une plus grande tendance à distinguer le traitement syntaxique et sémantique par rapport à l'hémisphère droit. Dans un dernier ensemble d'expériences, nous avons conçu une méthode qui contrôle les mécanismes d'attention dans les Transformers afin de générer des représentations qui utilisent un contexte de taille fixe. Cette approche fournit des preuves de la sensibilité au contexte dans la plupart du cortex. De plus, cette analyse a révélé que les hémisphères gauche et droit avaient tendance à traiter respectivement des informations contextuelles plus courtes et plus longues.
122406_PASQUIOU_2023_archivage.pdf (58.39 Mo) Télécharger le fichier
tel-04165565 , version 1 (19-07-2023)
  • HAL Id : tel-04165565 , version 1
Alexandre Pasquiou. Deciphering the neural bases of language comprehension using latent linguistic representations. Artificial Intelligence [cs.AI]. Université Paris-Saclay, 2023. English. ⟨NNT : 2023UPASG041⟩. ⟨tel-04165565⟩
77 Consultations
28 Téléchargements
