Advances in asymmetric cryptographic algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hdr Année : 2023
This document gives a synthetic overview of my research since 2006. It is focused on algorithms for asymmetric (public-key) cryptography—especially, though not exclusively, Elliptic Curve Cryptography; its generalizations including Hyperelliptic Curve Cryptography; and its derivatives including Isogeny-Based Cryptography, one of the newer branches of post-quantum cryptography. We also consider the implementation of post-quantum cryptosystems in a broader sense. The contributions range from theoretical and mathematical foundations through to low-level implementation techniques.
quick.pdf (313.83 Ko) Télécharger le fichier
tel-04238166 , version 1 (12-10-2023)
Paternité
  • HAL Id : tel-04238166 , version 1
Benjamin Smith. Advances in asymmetric cryptographic algorithms. Cryptography and Security [cs.CR]. Institut polytechnique de Paris, 2023. ⟨tel-04238166⟩
119 Consultations
106 Téléchargements
