Measures for knowledge – with applications to ontology matching and data interlinking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hdr Année : 2023
The Semantic Web is an extension of the web that enables people to express knowledge in a way that machines can reason with it. At the web scale, this knowledge may be described using different ontologies, and alignments have been defined to express these differences. Furthermore, the same individual may be represented by different instances in different datasets. Dealing with knowledge heterogeneity in the Semantic Web requires comparing these knowledge structures. Our objective is to understand heterogeneity and benefit from this understanding, not to reduce diversity. In this context, we have studied and contributed to techniques and measures for comparing knowledge structures on the Semantic Web along three dimensions: ontologies, alignments, and instances. At the ontology level, we propose measures for the ontology space and alignment space. The first family of measures relies solely on the content of ontologies, while the second one takes advantage of alignments between ontologies. At the alignment level, we investigate how to assess the quality of alignments. First, we study how to extend classical controlled evaluation measures by considering the semantics of aligned ontologies while relaxing the all-or-nothing nature of logical entailment. We also propose estimating the quality of alignments when no reference alignment is available. At the instance level, we tackle the challenge of identifying resources from different knowledge graphs that represent the same entity. We follow an approach based on keys and alignments. Specifically, we propose the notion of a link key, algorithms for extracting them, and measures to assess their quality. Finally, we recast this work in the perspective of the dynamics and evolution of knowledge.
2023_hdr_jerome_david_final.pdf (624.26 Ko) Télécharger le fichier
Licence : CC BY SA - Paternité - Partage selon les Conditions Initiales
tel-04357558 , version 1 (21-12-2023)
  • HAL Id : tel-04357558 , version 1
Jérôme David. Measures for knowledge – with applications to ontology matching and data interlinking. Computer Science [cs]. Université Grenoble Alpes, 2023. ⟨tel-04357558⟩
36 Consultations
26 Téléchargements
