Combined inversion methods for inverse conductivity problems
Méthodes d'inversion combinées pour les problèmes inverses de conductivité
In this thesis, we develop an inversion method that combines the use of a Kohn-Vogelius
type cost functional with a non-overlapping domain decomposition method as an iterative
solver. The idea behind this method is to iterate simultaneously on the solution of the direct
problem using the domain decomposition method and on the unknown of the inverse problem
using gradient descent on the Kohn-Vogelius cost functional. This type of approach falls into
the category of ”one-shot inversion methods,” and its use has the potential to significantly
reduce the cost of inversion when the numerical solution of the direct problem is costly. We
are particularly interested in the case of geometric inverse problems where the unknown of
the inverse problem is the support of a physical parameter’s discontinuity. The developments
made in this area were modeled on the inverse electrical conductivity problem, where the goal
is to reconstruct the conductivity discontinuity interface from Cauchy data on the domain
boundary. We prove the local convergence of the method in simplified cases and numerically
show its efficiency for some two dimensional experiments with synthetic data. Additionally,
we extend our approach to the more complex case where we also iterate on the value of con-
ductivity. In this context, we have also developed an alternating inversion algorithm between
the geometry and the inner value of the conductivity, with an adaptive descent step.
Dans cette thèse, nous développons une méthode d'inversion qui combine l'utilisation d'une fonctionnelle coût de type Kohn-Vogelius avec une méthode de décomposition de domaine sans recouvrement en tant que solveur itératif. L'idée derrière cette méthode est d'itérer simultanément sur la solution du problème direct via la méthode de décomposition de domaine et sur l'inconnue du problème inverse en utilisant une descente de gradient sur la fonctionnelle de Kohn-Vogelius. Ce type d'approche fait partie de la famille des méthodes dites "one-shot inversion methods", et son utilisation a le potentiel de réduire sensiblement le coût de l'inversion lorsque la résolution du problème direct est coûteuse. Nous nous intéressons plus particulièrement au cas des problèmes inverses géométriques où l'inconnue du problème inverse est le support d'une discontinuité d'un paramètre physique. Les développements réalisés sur cette thématique ont pris pour modèle inverse le problème inverse de conductivité électrique, où l'on cherche à reconstruire l'interface de discontinuité de la conductivité à partir de données de Cauchy sur la frontière du domaine. Nous prouvons un résultat de convergence locale de la méthode dans des cas simplifiés et l'avons validée numériquement pour certaines expériences bidimensionnelles avec des données synthétiques. De plus, nous étendons notre approche au cas plus complexe où l'on itère également sur la valeur de la conductivité. Dans ce contexte, nous avons également développé un algorithme d'inversion alternée entre la géométrie et la valeur intérieure de la conductivité, avec un pas de descente adaptatif.
