A step toward calculating the uncertainties in combined GIXRF-XRR - CEA - Université Paris-Saclay Accéder directement au contenu
Article Dans Une Revue X-Ray Spectrometry Année : 2023
The combination of XRR and GIXRF is used for the characterization of thin films and multilayered materials, since both techniques use similar measuring and data analysis procedures and combining them leads to more accurate characterization in terms of thickness, roughness, density and elemental composition. However, there is a major difficulty to determine the associated uncertainties, due to the large number of fitting parameters and more specifically, to the combination of the two methods with dramatically different dynamic ranges. In this paper, we propose a recursive method for the estimation of the uncertainties of the data from the GIXRF-XRR analysis, based on a Bootstrap statistical method. We applied this method on a one layer chalcogenide GST thin film with a carbon caping layer for which we found small uncertainties on the model parameters. We propose also a method for calculating the uncertainty on the solid angle of the detector based on Monte Carlo simulation.
A step toward calculating the uncertainties in combined GIXRF_XRR_SMELHEM.pdf (2.69 Mo) Télécharger le fichier
Origine : Publication financée par une institution
licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
cea-04563756 , version 1 (30-04-2024)
Stéphanie Melhem, Yves Ménesguen, Emmanuel Nolot, Marie-Christine Lépy. A step toward calculating the uncertainties in combined GIXRF-XRR. X-Ray Spectrometry, 2023, 52, pp.412-422. ⟨10.1002/xrs.3377⟩. ⟨cea-04563756⟩
8 Consultations
1 Téléchargements
