Comparison between binary64 and decimal64 floating-point numbers
We introduce an algorithm that allows one to quickly compare a binary64 floating-point (FP) number and a decimal64 FP number, assuming the "binary encoding" of the decimal formats specified by the IEEE 754-2008 standard for FP arithmetic is used. It is a two-step algorithm: a first pass, based on the exponents only, makes it possible to quickly eliminate most cases, then when the first pass does not suffice, a more accurate second pass is required. We provide an implementation of several variants of our algorithm, and compare them.
Compar-Arith.pdf (283.93 Ko)
Télécharger le fichier
compbindec-1.0.tar.xz (7.05 Mo)
Format : Autre
