Comparison between binary64 and decimal64 floating-point numbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce an algorithm that allows one to quickly compare a binary64 floating-point (FP) number and a decimal64 FP number, assuming the "binary encoding" of the decimal formats specified by the IEEE 754-2008 standard for FP arithmetic is used. It is a two-step algorithm: a first pass, based on the exponents only, makes it possible to quickly eliminate most cases, then when the first pass does not suffice, a more accurate second pass is required. We provide an implementation of several variants of our algorithm, and compare them.
Autre [cs.OH]
Compar-Arith.pdf (283.93 Ko) Télécharger le fichier
compbindec-1.0.tar.xz (7.05 Mo) Télécharger le fichier
Format : Autre
ensl-00737881 , version 1 (03-10-2012)
ensl-00737881 , version 2 (07-02-2013)
ensl-00737881 , version 3 (11-02-2013)
ensl-00737881 , version 4 (11-02-2013)
  • HAL Id : ensl-00737881 , version 3
Nicolas Brisebarre, Marc Mezzarobba, Jean-Michel Muller, Christoph Lauter. Comparison between binary64 and decimal64 floating-point numbers. 21st IEEE Symposium on Computer Arithmetic, Apr 2013, Austin, TX, United States. pp.8. ⟨ensl-00737881v3⟩
1080 Consultations
1052 Téléchargements
