Lift of $C_\infty$ and $L_\infty$ morphisms to $G_\infty$ morphisms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2005
Let $\g_2$ be the Hochschild complex of cochains on $C^\infty(\RM^n)$ and $\g_1$ be the space of multivector fields on $\RM^n$. In this paper we prove that given any $G_\infty$-structure ({\rm i.e.} Gerstenhaber algebra up to homotopy structure) on $\g_2$, and any $C_\infty$-morphism $\varphi$ ({\rm i.e.} morphism of commutative, associative algebra up to homotopy) between $\g_1$ and $\g_2$, there exists a $G_\infty$-morphism $\Phi$ between $\g_1$ and $\g_2$ that restricts to $\varphi$. We also show that any $L_\infty$-morphism ({\rm i.e.} morphism of Lie algebra up to homotopy), in particular the one constructed by Kontsevich, can be deformed into a $G_\infty$-morphism, using Tamarkin's method for any $G_\infty$-structure on $\g_2$. We also show that any two of such $G_\infty$-morphisms are homotopic.
lift100303.pdf (80.04 Ko) Télécharger le fichier
hal-00000272 , version 1 (01-04-2003)
hal-00000272 , version 2 (29-06-2005)
hal-00000272 , version 3 (29-06-2005)
Grégory Ginot, Gilles Halbout. Lift of $C_\infty$ and $L_\infty$ morphisms to $G_\infty$ morphisms. 2005. ⟨hal-00000272v2⟩
102 Consultations
162 Téléchargements
