A Pickands type estimator of the extreme value index - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2004
Laurent Gardes
  • Fonction : Auteur
  • PersonId : 911294
One of the main goal of extreme value analysis is to estimate the probability of rare events given a sample from an unknown distribution. The upper tail behavior of this distribution is described by the extreme value index. We present a new estimator of the extreme value index adapted to any domain of attraction. Its construction is similar to the one of Pickands' estimator. its weak consistency and its asymptotic distribution are established and a bias reduction method is proposed. Our estimator is compared with classical extreme value index estimators through a simulation study.
extremevalue.pdf (251.81 Ko) Télécharger le fichier
hal-00001307 , version 1 (18-03-2004)
Laurent Gardes, Stéphane Girard. A Pickands type estimator of the extreme value index. 2004. ⟨hal-00001307⟩
Collections
UGA CNRS LMC-IMAG
200 Consultations
191 Téléchargements
