Comparison of Weibull tail-coefficient estimators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2005
We address the problem of estimating the Weibull tail-coefficient which is the regular variation exponent of the inverse failure rate function. We propose a family of estimators of this coefficient and an associate extreme quantile estimator. Their asymptotic normality are established and their asymptotic mean-square errors are compared. The results are illustrated on some finite sample situations
girard.pdf (193.04 Ko) Télécharger le fichier
hal-00009006 , version 1 (22-09-2005)
hal-00009006 , version 2 (09-03-2006)
  • HAL Id : hal-00009006 , version 1
Laurent Gardes, Stéphane Girard. Comparison of Weibull tail-coefficient estimators. 2005. ⟨hal-00009006v1⟩
288 Consultations
148 Téléchargements
