Approximation by Generalized Impedance Boundary Conditions of a Transmission Problem in Acoustic Scattering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2005
This paper addresses some results on the development of an approximate method for computing the acoustic field scattered by a three-dimensional penetrable object immersed into an incompressible fluid. The basic idea of the method consists in using on-surface differential operators that locally reproduce the interior propagation phenomenon. This approach leads to integral equation formulations with a reduced computational cost compared to standard integral formulations coupling both the transmitted and scattered waves. Theoretical aspects of the problem and numerical experiments are reported to analyze the efficiency of the method and precise its validity domain.
hal-00091669 , version 1 (06-09-2006)
Xavier Antoine, Hélène Barucq. Approximation by Generalized Impedance Boundary Conditions of a Transmission Problem in Acoustic Scattering. ESAIM: Mathematical Modelling and Numerical Analysis, 2005, 39 (5), pp.1041-1059. ⟨10.1051/m2an:2005037⟩. ⟨hal-00091669⟩
144 Consultations
0 Téléchargements
