A new hyperbolic visualization method for displaying the results of a neural gas model: application to webometrics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Shadi Al Shehabi
  • Fonction : Auteur
  • PersonId : 831198
Jean-Charles Lamirel
The core model which is considered in this paper is the neural gas model. This paper proposes an original hyperbolic visualization approach which is suitable to be applied on the results of such a model. The main principle of this approach is to use a hierarchical algorithm in order to summarize the gas contents in the form on a hypertree in which information on data density issued from the original neurons (i.e. clusters) description space is preserved. An application of this approach on a dataset of websites issued from European universities is presented in order to prove its accuracy.
Fichier non déposé
hal-00104601 , version 1 (08-10-2006)
  • HAL Id : hal-00104601 , version 1
Shadi Al Shehabi, Jean-Charles Lamirel. A new hyperbolic visualization method for displaying the results of a neural gas model: application to webometrics. 2006, pp.295--300. ⟨hal-00104601⟩
116 Consultations
0 Téléchargements
