MultiSOM: a multiview neural model for accurately analyzing and mining complex data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Jean-Charles Lamirel
Shadi Al Shehabi
  • Fonction : Auteur
  • PersonId : 831198
In the procedure of information analysis, like in the domain of patent analysis, the complexity of the studied topics and the accuracy of the question to be answered may often lead the analyst to partition his reasoning into viewpoints. Most of the classical information analysis tools can only manage an analysis of the studied domain in a global way. The information analysis tool is considered in this paper is the MultiSOM tool, whose core model represents a significant extension of the classical Kohonen SOM neural model. The MultiSOM neural-based tool introduces the concepts of viewpoints and dynamics into the information analysis with its multi-maps displays and its inter-map communication process. The dynamic information exchange between maps can be exploited by an analyst in order to perform cooperative deduction between several different analyzes that have been performed on the same data. This paper demonstrates the efficiency of a viewpoint-oriented analysis as compared to a global analysis in the domain of patents. Both objective and subjective quality criteria are taken into account for quality evaluation.
Fichier non déposé
hal-00104604 , version 1 (08-10-2006)
  • HAL Id : hal-00104604 , version 1
Jean-Charles Lamirel, Shadi Al Shehabi. MultiSOM: a multiview neural model for accurately analyzing and mining complex data. 2006, pp.42--54. ⟨hal-00104604⟩
154 Consultations
0 Téléchargements
