An algorithm for automatically obtaining distributed and fault-tolerant static schedules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Embedded systems account for a major part of crit- ical applications (space, aeronautics, nuclear. . . ) as well Our goal is to automatically obtain a distributed and as public domain applications (automotive, consumer fault-tolerant embedded system: distributed because the electronics. . . ). Their main features are: system must run on a distributed architecture; fault-tolerant because the system is critical. Our starting point is a source algorithm, a target distributed architecture, some distribu- tion constraints, some indications on the execution times of the algorithm operations on the processors of the target ar- chitecture, some indications on the communication times of the data-dependencies on the communication links of the target architecture, a number Npf of fail-silent processor failures that the obtained system must tolerate, and finally some real-time constraints that the obtained system must satisfy. In this article, we present a scheduling heuristic which, given all these inputs, produces a fault-tolerant, dis- tributed, and static scheduling of the algorithm on the ar- chitecture, with an indication whether or not the real-time constraints are satisfied. The algorithm we propose consist of a list scheduling heuristic based active replication strat- egy, that allows at least Npf +1 replicas of an operation to be scheduled on different processors, which are run in parallel to tolerate at most Npf failures. Due to the strat- egy used to schedule operations, simulation results show that the proposed heuristic improve the performance of our method, both in the absence and in the presence of failures.
main.pdf (910.86 Ko) Télécharger le fichier
hal-00110453 , version 1 (30-10-2006)
  • HAL Id : hal-00110453 , version 1
Alain Girault, Hamoudi Kalla, Mihaela Sighireanu, Yves Sorel. An algorithm for automatically obtaining distributed and fault-tolerant static schedules. Jun 2003, pp.165-190. ⟨hal-00110453⟩
258 Consultations
269 Téléchargements
