Fast computation of discrete invariants associated to a differential rational mapping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2003
We exhibit probabilistic algorithms which compute the differentiation index, the differential Hilbert function and a parametric set associated to a differential rational mapping. These algorithms are based on a process of linearization and specialization in a generic solution, and have polynomial time complexity.
MateraSedoglavic2003a.pdf (296.75 Ko) Télécharger le fichier
hal-00129198 , version 1 (06-02-2007)
Guillermo Matera, Alexandre Sedoglavic. Fast computation of discrete invariants associated to a differential rational mapping. Journal of Symbolic Computation, 2003, 36 (3--4), pp.473--499. ⟨10.1016/S0747-7171(03)00091-9⟩. ⟨hal-00129198⟩
384 Consultations
132 Téléchargements
