Mobility control via passports - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information and Computation Année : 2009
Dpi is a simple distributed extension of the pi-calculus in which agents are explicitly located, and may use an explicit migration construct to move between locations. In this paper we introduce passports to control those migrations; in order to gain access to a location agents are now expected to show some credentials, granted by the destination location. Passports are tied to specific locations, from which migration is permitted. We describe a type system for these passports, which includes a novel use of dependent types, and prove that well-typing enforces the desired behaviour in migrating processes. Passports allow locations to control incoming processes. This induces a major modification to the possible observations which can be made of agent-based systems. Using the type system we describe these observations, and use them to build a loyal notion of observational equivalence for this setting. Finally we provide a complete proof technique in the form of a bisimilarity for establishing equivalences between systems.
Hym_Mobility_control_via_passports.pdf (309.1 Ko) Télécharger le fichier
hal-00140527 , version 1 (06-04-2007)
Samuel Hym. Mobility control via passports. Information and Computation, 2009, 207 (2), pp.171-193. ⟨10.1016/j.ic.2007.11.011⟩. ⟨hal-00140527⟩
87 Consultations
135 Téléchargements
