Mobility control via passports
Dpi is a simple distributed extension of the pi-calculus in which agents are explicitly located, and may use an explicit migration construct to move between locations. In this paper we introduce passports to control those migrations; in order to gain access to a location agents are now expected to show some credentials, granted by the destination location. Passports are tied to specific locations, from which migration is permitted. We describe a type system for these passports, which includes a novel use of dependent types, and prove that well-typing enforces the desired behaviour in migrating processes. Passports allow locations to control incoming processes. This induces a major modification to the possible observations which can be made of agent-based systems. Using the type system we describe these observations, and use them to build a loyal notion of observational equivalence for this setting. Finally we provide a complete proof technique in the form of a bisimilarity for establishing equivalences between systems.
Origin | Files produced by the author(s) |
