A Sequent Calculus for Type Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Based on natural deduction, Pure Type Systems (PTS) can express a wide range of type theories. In order to express proof-search in such theories, we introduce the Pure Type Sequent Calculi (PTSC) by enriching a sequent calculus due to Herbelin, adapted to proof-search and strongly related to natural deduction. PTSC are equipped with a normalisation procedure, adapted from Herbelin's and defined by local rewrite rules as in Cut-elimination, using explicit substitutions. It satisfies Subject Reduction and it is confluent. A PTSC is logically equivalent to its corresponding PTS, and the former is strongly normalising if and only if the latter is. We show how the conversion rules can be incorporated inside logical rules (as in syntax-directed rules for type checking), so that basic proof-search tactics in type theory are merely the root-first application of our inference rules.
Fichier non déposé
hal-00150286 , version 1 (30-05-2007)
  • HAL Id : hal-00150286 , version 1
Stéphane Lengrand, Roy Dyckhoff, James Mckinna. A Sequent Calculus for Type Theory. Computer Science Logic (CSL'06), Sep 2006, Szeged, Hungary. pp.441 - 455. ⟨hal-00150286⟩
273 Consultations
0 Téléchargements
