Infinite special branches in words associated with beta-expansions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2007
A Parry number is a real number β > 1 such that the Rényi β-expansion of 1 is finite or infinite eventually periodic. If this expansion is finite, β is said to be a simple Parry number. Remind that any Pisot number is a Parry number. In a previous work we have determined the complexity of the fixed point uβ of the canonical substitution associated with β-expansions, when β is a simple Parry number. In this paper we consider the case where β is a non-simple Parry number. We determine the structure of infinite left special branches, which are an important tool for the computation of the complexity of uβ. These results allow in particular to obtain the following characterization: the infinite word uβ is Sturmian if and only if β is a quadratic Pisot unit.
658-2321-1-PB.pdf (250.37 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00159681 , version 1 (03-06-2014)
Christiane Frougny, Zuzana Masáková, Edita Pelantová. Infinite special branches in words associated with beta-expansions. Discrete Mathematics and Theoretical Computer Science, 2007, Vol. 9 no. 2 (2), pp.125-144. ⟨10.46298/dmtcs.415⟩. ⟨hal-00159681⟩
111 Consultations
531 Téléchargements
