Dynamic 2D Patterns for Shading 3D Scenes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2007
We describe a new way to render 3D scenes in a variety of non-photorealistic styles, based on patterns whose structure and motion are defined in 2D. In doing so, we sacrifice the ability of patterns that wrap onto 3D surfaces to convey shape through their structure and motion. In return, we gain several advantages, chiefly that 2D patterns are more visually abstract - a quality often sought by artists, which explains their widespread use in hand-drawn images. Extending such styles to 3D graphics presents a challenge: how should a 2D pattern move? Our solution is to transform it each frame by a 2D similarity transform that closely follows the under-lying 3D shape. The resulting motion is often surprisingly effective, and has a striking cartoon quality that matches the visual style.
d2d-s07.pdf (525.11 Ko) Télécharger le fichier
Format : Figure, Image
hal-00171415 , version 1 (29-04-2011)
Simon Breslav, Karol Szerszen, Lee Markosian, Pascal Barla, Joëlle Thollot. Dynamic 2D Patterns for Shading 3D Scenes. ACM Transactions on Graphics, 2007, 26 (3), pp.20-20:5. ⟨10.1145/1276377.1276402⟩. ⟨hal-00171415⟩
686 Consultations
1097 Téléchargements
