Fine Grain QoS Control for Multimedia Application Software - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Jacques Combaz
  • Fonction : Auteur
Jean-Claude Fernandez
  • Fonction : Auteur
Thierry Lepley
  • Fonction : Auteur
Joseph Sifakis
  • Fonction : Auteur
We propose a method for fine grain QoS control of dataflow applications. We assume that the application software is described as the composition of actions (C-functions) with quality level parameters. The method allows to compute a QoS controller from this description, and average execution times, worst case execution times and deadlines for its actions. The controller computes dynamically feasible schedules and quality assignments for their actions. Furthermore, the control policy ensures optimal time budget utilization. A prototype tool implementing the method is shown as well as experimental results for a non trivial example. The results show the interest of fine grain QoS control for video encoders.
228821038.pdf (180.42 Ko) Télécharger le fichier
hal-00181681 , version 1 (24-10-2007)
  • HAL Id : hal-00181681 , version 1
Jacques Combaz, Jean-Claude Fernandez, Thierry Lepley, Joseph Sifakis. Fine Grain QoS Control for Multimedia Application Software. DATE'05, Mar 2005, Munich, Germany. pp.1038-1043. ⟨hal-00181681⟩
143 Consultations
77 Téléchargements
