On locally self-similar fractional random fields indexed by a manifold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastics: An International Journal of Probability and Stochastic Processes Année : 2013
Local self-similarity for Euclidean random fields has been introduced since a while. In this paper, we define local self-similarity for manifold indexed random fields. We study the properties of the tangent field. In the Gaussian and stable cases, we obtain the expected relations between the fractional index and the stability index. We then give examples.
IL-LASS.pdf (151.5 Ko) Télécharger le fichier
hal-00193203 , version 1 (03-12-2007)
hal-00193203 , version 2 (14-11-2011)
Jacques Istas, Céline Lacaux. On locally self-similar fractional random fields indexed by a manifold. Stochastics: An International Journal of Probability and Stochastic Processes, 2013, 85 (3), pp.489-499. ⟨10.1080/17442508.2012.654609⟩. ⟨hal-00193203v2⟩
213 Consultations
405 Téléchargements
