On locally self-similar fractional random fields indexed by a manifold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
Jacques Istas
  • Fonction : Auteur
  • PersonId : 844907
Céline Lacaux
Local self-similarity for Euclidean random fields has been introduced since a while. In this paper, we define local self-similarity for manifold indexed random fields. We study the properties of the tangent field. In the Gaussian and stable cases, we obtain the expected relations between the fractional index and the stability index. We then give examples.
IL-lass-071125.pdf (201.43 Ko) Télécharger le fichier
hal-00193203 , version 1 (03-12-2007)
hal-00193203 , version 2 (14-11-2011)
  • HAL Id : hal-00193203 , version 1
Jacques Istas, Céline Lacaux. On locally self-similar fractional random fields indexed by a manifold. 2007. ⟨hal-00193203v1⟩
217 Consultations
411 Téléchargements
