Non-asymptotic resampling-based confidence regions and multiple tests in high dimension - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
We study generalized bootstrapped confidence regions for the mean of a random vector whose coordinates have an unknown dependence structure. The dimensionality of the vector can possibly be much larger than the number of observations and we focus on a non-asymptotic control of the confidence level. The random vector is supposed to be either Gaussian or to have a symmetric bounded distribution. We consider two approaches, the first based on a concentration principle and the second on a direct bootstrapped quantile. The first one allows us to deal with a very large class of resampling weights while our results for the second are specific to Rademacher weights. We present an application of these results to the one-sided and two-sided multiple testing problem, in which we derive several resampling-based step-down procedures providing a non-asymptotic FWER control. We compare our different procedures in a simulation study, and we show that they can outperform Bonferroni's or Holm's procedures as soon as the observed vector has sufficiently correlated coordinates.
ABR07long_Hal.pdf (516.08 Ko) Télécharger le fichier
hal-00194145 , version 1 (05-12-2007)
hal-00194145 , version 2 (06-07-2009)
Sylvain Arlot, Gilles Blanchard, Etienne Roquain. Non-asymptotic resampling-based confidence regions and multiple tests in high dimension. 2007. ⟨hal-00194145v1⟩
Collections
LM-ORSAY
507 Consultations
496 Téléchargements
