Learning saliency maps for object categorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We present a novel approach for object category recognition that can find objects in challenging conditions using visual attention technique. It combines saliency maps very closely with the extraction of random subwindows for classification purposes. The maps are built online by the classifier while being used by it to classify the image.
MLJ06.pdf (617.68 Ko) Télécharger le fichier
hal-00203726 , version 1 (21-01-2008)
  • HAL Id : hal-00203726 , version 1
Franck Moosmann, Diane Larlus, Frédéric Jurie. Learning saliency maps for object categorization. International Workshop on The Representation and Use of Prior Knowledge in Vision (in ECCV '06), May 2006, Graz, Austria. ⟨hal-00203726⟩
694 Consultations
677 Téléchargements
