Simulating Prostate Surgical Procedures with a Discrete Soft Tissue Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Simulating surgical procedures is still a complex challenge. Either modeling methods or simulators have to take into account specific geometries and properties of the patient organs. In this paper, a new soft tissue modeling method dedicated to prostate surgical interventions is presented. The chosen medical application requires the modeling of a complex anatomical environment including intricate interactions between organs and surgical instruments. We present a discrete model that has been specifically developed to fulfil these requirements. The influence of two particular instruments is studied: needles and ultrasound probe, according to two surgical interventions: biopsy and brachytherapy.
MMarchal_VriPhys06.pdf (6.08 Mo) Télécharger le fichier
hal-00206191 , version 1 (16-01-2008)
  • HAL Id : hal-00206191 , version 1
Maud Marchal, Emmanuel Promayon, Jocelyne Troccaz. Simulating Prostate Surgical Procedures with a Discrete Soft Tissue Model. Third Eurographics Workshop in Virtual Reality Interactions and Physical Simulation, Nov 2006, Madrid, Spain. pp. 109-118. ⟨hal-00206191⟩
1243 Consultations
63 Téléchargements
