Tracking fast changing non-stationary distributions with a topologically adaptive neural network: Application to video tracking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Hervé Frezza-Buet
In this paper, an original method named GNG-T, extended from GNG-U algorithm by Fritzke is presented. The method performs continuously vector quantization over a distribution that changes over time. It deals with both sudden changes and continuous ones, and is thus suited for video tracking framework, where continuous tracking is required as well as fast adaptation to incoming and outgoing people. The central mechanism relies on the management of quantization resolution, that cope with stopping condition problems of usual Growing Neural Gas inspired methods. Application to video tracking is briefly presented.
es2007-89.pdf (617.53 Ko) Télécharger le fichier
hal-00250981 , version 1 (12-02-2008)
  • HAL Id : hal-00250981 , version 1
Georges Adrian Drumea, Hervé Frezza-Buet. Tracking fast changing non-stationary distributions with a topologically adaptive neural network: Application to video tracking. 15th European Symposium on Artificial Neural Networks (ESANN2007), Apr 2007, Bruges, Belgium. pp.43-48. ⟨hal-00250981⟩
61 Consultations
98 Téléchargements
