Bohr-Neugebauer type theorem for some partial neutral functional differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2006
In this work, we study the existence of almost periodic solutions for some partial neutral functional differential equations. Using the variation of constants formulaand the spectral decomposition of the phase space developed in [6], we prove that the existence of an almost periodic solution is equivalent to the existence of a bounded solution on $\mathbb{R}^+$.
0608.pdf (170.71 Ko) Télécharger le fichier
hal-00258398 , version 1 (22-02-2008)
  • HAL Id : hal-00258398 , version 1
Mostafa Adimy, Abdelhai Elazzouzi, Khalil Ezzinbi. Bohr-Neugebauer type theorem for some partial neutral functional differential equations. 2006. ⟨hal-00258398⟩
366 Consultations
245 Téléchargements
