Testing for Homogeneity with Kernel Fisher Discriminant Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
We propose to investigate test statistics for testing homogeneity in reproducing kernel Hilbert spaces. Asymptotic null distributions under null hypothesis are derived, and consistency against fixed and local alternatives is assessed. Finally, experimental evidence of the performance of the proposed approach on both artificial data and a speaker verification task is provided.
ktest_v1.pdf (406.82 Ko) Télécharger le fichier
hal-00270806 , version 1 (07-04-2008)
Zaid Harchaoui, Francis Bach, Eric Moulines. Testing for Homogeneity with Kernel Fisher Discriminant Analysis. 2008. ⟨hal-00270806⟩
774 Consultations
414 Téléchargements
