Waiting Time Distribution for Pattern Occurrence in a Constrained Sequence: an Embedding Markov Chain Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2008
Gregory Nuel
In this paper we consider the distribution of a pattern of interest in a binary random (d; k)-sequence generated by a Markov source. Such constrained sequences are frequently encountered in communication systems. Unlike the previous approach based on generating function we have chosen here to use Markov chain embedding techniques. By doing so, we get both previous results (sequence constrained up to the rth occurrence), and new ones (sequence constrained up to its end). We also provide in both cases efficient algorithms using basic linear algebra only. We then compare our numerical results to previous ones and finally propose several interesting extensions of our method which further illustrate the usefulness of our approach. That is to say higher order Markov chains, renewal occurrences rather than overlapping ones, heterogeneous models, more complex patterns of interest, and multistate trial sequences.
739-3734-1-PB.pdf (214.91 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00271314 , version 1 (03-06-2014)
Gregory Nuel. Waiting Time Distribution for Pattern Occurrence in a Constrained Sequence: an Embedding Markov Chain Approach. Discrete Mathematics and Theoretical Computer Science, 2008, Vol. 10 no. 3 (3), pp.149-160. ⟨10.46298/dmtcs.449⟩. ⟨hal-00271314⟩
95 Consultations
697 Téléchargements
