A METHOD OF RECOGNIZING A MOTION PATTERN OF AN OBJECT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brevet Année : 2008
Olivier Pietquin
A method and a motion recognition system is disclosed for recognizing a motion pattern of at least one object by means of determining relative motion blur variations around the at least on object in an image or a sequence of images. Motion blur parameters are extracted from the motion blur in the images, and based thereon the motion blur variations are determined by means of determining variations between the motion blur parameters.
Fichier non déposé
hal-00280122 , version 1 (16-05-2008)
  • HAL Id : hal-00280122 , version 1
Olivier Pietquin. A METHOD OF RECOGNIZING A MOTION PATTERN OF AN OBJECT. France, Patent n° : EP1904951. 2008, pp.18. ⟨hal-00280122⟩
20 Consultations
0 Téléchargements
