Numerical analysis of the generalized Maxwell equations (with an elliptic correction) for charged particle simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
When computing numerical solutions to the Vlasov--Maxwell equations, the source terms in Maxwell's equations usually fail to satisfy the continuity equation. Since this condition is required for the well-posedness of Maxwell's equations, it is necessary to introduce generalized Maxwell's equations which remain well-posed when there are errors in the sources. These approaches, which involve a hyperbolic, a parabolic and an elliptic correction, have been recently analyzed mathematically. The goal of this paper is to carry out the numerical analysis for several variants of Maxwell's equations with an elliptic correction.
CiLa08a.pdf (370.11 Ko) Télécharger le fichier
hal-00291503 , version 1 (27-06-2008)
hal-00291503 , version 2 (02-07-2008)
  • HAL Id : hal-00291503 , version 1
Patrick Ciarlet, Simon Labrunie. Numerical analysis of the generalized Maxwell equations (with an elliptic correction) for charged particle simulations. 2008. ⟨hal-00291503v1⟩
Collections
ENSTA
222 Consultations
244 Téléchargements
