Ontology-Directed Generation of Frameworks For Pervasive Service Development - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Pervasive computing applications are tedious to develop because they combine a number of problems ranging from device heterogeneity, to middleware constraints, to lack of programming support. In this paper, we present an approach to integrating the ontological description of a pervasive computing environment into a programming language, namely Java. From this ontological description of a pervasive computing environment, a framework is automatically generated. It provides the developer with dedicated programming support to manage, discover and invoke services. Besides, it performs a number of verifications both at compile and run time, ensuring the robustness of applications
Autre [cs.OH]
consel_al_perware_0_.pdf (178.29 Ko) Télécharger le fichier
hal-00306009 , version 1 (25-07-2008)
  • HAL Id : hal-00306009 , version 1
Charles Consel, Wilfried Jouve, Julien Lancia, Nicolas Palix. Ontology-Directed Generation of Frameworks For Pervasive Service Development. Proceedings of The 4th IEEE Workshop on Middleware Support for Pervasive Computing (PerWare 07), Mar 2007, United States. pp.501 - 508. ⟨hal-00306009⟩
79 Consultations
167 Téléchargements
