Volume preservation of multiresolution meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2007
Geometric constraints have proved to be efficient for improving the realism of shape animation. The present paper addresses the computation and the preservation of the volume enclosed by multiresolution meshes. A wavelet based representation allows the mesh to be handled at any level of resolution. The key contribution is the calculation of the volume as a trilinear form with respect to the multiresolution coefficients. Efficiency is reached thanks to the pre-processing of a sparse 3D data structure involving the transposition of the filters while represented as a lifting scheme. A versatile and interactive method for preserving the volume during a deformation process is then proposed. It is based on a quadratic minimization subject to a linearization of the volume constraint.
SHB07-EG.pdf (933.72 Ko) Télécharger le fichier
VideoSubmissionLongID1131.wmv (3.62 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-00319628 , version 1 (08-09-2008)
Basile Sauvage, Stefanie Hahmann, Georges-Pierre Bonneau. Volume preservation of multiresolution meshes. Computer Graphics Forum, 2007, 26 (3), pp.275-283. ⟨10.1111/j.1467-8659.2007.01049.x⟩. ⟨hal-00319628⟩
746 Consultations
703 Téléchargements
