Detail Preserving Deformation of B-spline Surfaces with Volume Constraint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Aided Geometric Design Année : 2008
Geometric constraints have proved to be helpful for shape modeling. Moreover, they are efficient aids in controlling deformations and enhancing animation realism. The present paper adresses the deformation of B-spline surfaces while constraining the volume enclosed by the surface. Both uniform and non-uniform frameworks are considered. The use of level-of-detail (LoD) editing allows the preservation of tne details during coarse deformations of the shape. The key contribution of this paper is the computation of the volume with respect to the appropriate basis for LoD editing: the volume is expressed through all levels of resolution as a trilinear form and recursive formulas are developped to make the computation e±cient. The volume constrained is maintained through a minimization process for which we develop closed solutions. Real-time deformations are reached thanks to sparse data structures and e±cient algorithms.
SHBE07-cagd.pdf (1.96 Mo) Télécharger le fichier
Format : Figure, Image
hal-00319636 , version 1 (08-09-2008)
Basile Sauvage, Stefanie Hahmann, Georges-Pierre Bonneau, Gershon Elber. Detail Preserving Deformation of B-spline Surfaces with Volume Constraint. Computer Aided Geometric Design, 2008, 25 (8), pp.678-696. ⟨10.1016/j.cagd.2007.10.004⟩. ⟨hal-00319636⟩
700 Consultations
314 Téléchargements
