Area preserving deformation of multiresolution curves - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Computer Aided Geometric Design Year : 2005
We describe a method for multiresolution deformation of closed planar curves that keeps the enclosed area constant. We use a wavelet based multiresolution representation of the curves which are represented by a finite number of control points at each level of resolution. A deformation can then be applied to the curve by modifying one or more control points at any level of resolution. This process is generally known as multiresolution editing to which we add the constraint of constant area. A multiresolution representation for the area moment is also developed. We make sure that all computations are fast and that the deformations can be performed interactively. Diverse types of deformation are discussed.
HSB05-cagd.pdf (331.18 Ko) Télécharger le fichier
Dates and versions
hal-00319648 , version 1 (09-09-2008)
Identifiers
Cite
Stefanie Hahmann, Basile Sauvage, Georges-Pierre Bonneau. Area preserving deformation of multiresolution curves. Computer Aided Geometric Design, 2005, 22 (4), pp.349-367. ⟨10.1016/j.cagd.2005.01.006⟩. ⟨hal-00319648⟩
344 View
292 Download
Share
