Design with free-form splines over irregular meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Generating smooth surfaces of arbitrary topology is still a challenge. This paper considers the problem of creating a smooth parametric polynomial surface interpolating the vertices of an irregular triangular or quadrilateral mesh of arbitrary topological type.
Fichier non déposé
hal-00319654 , version 1 (09-09-2008)
Stefanie Hahmann, Georges-Pierre Bonneau, Sébastien Barbier, Mélanie Cornillac. Design with free-form splines over irregular meshes. ASME Conference on Engineering Systems Design and Analysis 2008, Jul 2008, Haifa, Israel. pp.155-162, ⟨10.1115/ESDA2008-59302⟩. ⟨hal-00319654⟩
226 Consultations
0 Téléchargements
