Estimating extreme quantiles of Weibull tail-distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Statistics - Theory and Methods Année : 2005
We present a new estimator of extreme quantiles dedicated to Weibull tail-distributions. This estimate is based on a consistent estimator of the Weibull tail-coefficient. This parameter is defined as the regular variation coefficient of the inverse cumulative hazard function. We give conditions in order to obtain the weak consistency and the asymptotic distribution of the extreme quantiles estimator. Its asymptotic as well as its finite sample performances are compared to classical ones.
RR1065.pdf (215.11 Ko) Télécharger le fichier
hal-00326609 , version 1 (03-10-2008)
  • HAL Id : hal-00326609 , version 1
Laurent Gardes, Stéphane Girard. Estimating extreme quantiles of Weibull tail-distributions. Communications in Statistics - Theory and Methods, 2005, 34, pp.1065-1080. ⟨hal-00326609⟩
Collections
INRIA INRIA2
175 Consultations
658 Téléchargements
