Weibull tail-distributions revisited: a new look at some tail estimators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
In this paper, we propose to include Weibull tail-distributions in a more general family of distributions. In particular, the considered model also encompasses the whole Fréchet maximum domain of attraction as well as log-Weibull tail-distributions. The asymptotic normality of some tail estimators based on the log-spacings between the largest order statistics is established in an unified way within the considered family. This result permits to understand the similarity between most estimators of the Weibull tail-coefficient and the Hill estimator. Some different asymptotic properties, in terms of bias, rate of convergence, are also highlighted.
gargirgui.pdf (229.37 Ko) Télécharger le fichier
hal-00340661 , version 1 (21-11-2008)
hal-00340661 , version 2 (07-12-2009)
hal-00340661 , version 3 (20-05-2010)
hal-00340661 , version 4 (14-06-2010)
  • HAL Id : hal-00340661 , version 3
Laurent Gardes, Stéphane Girard, Armelle Guillou. Weibull tail-distributions revisited: a new look at some tail estimators. 2009. ⟨hal-00340661v3⟩
371 Consultations
1335 Téléchargements
