s'authentifier
version française rss feed
hal-00344362, version 1
MPICH/MadIII: a Cluster of Clusters-Enabled MPI Implementation
Guillaume Mercier () 1, Olivier Aumage 2
Third IEEE International Symposium on Cluster Computing and the Grid (CCGRID'03) (2003) 26--35
Résumé : This paper presents an MPI implementation that allows an easy and efficient use of the interconnection of several clusters, of potentially heterogeneous nature (as far as the network is concerned). We describe the underlying communication subsystem used. The mechanisms within MPI that inform the user of the underlying topological structure are detailed. The performance figures obtained with this MPI implementation are discussed and advocate for the use of such a solution on this particular type of architecture.
  • Domaine : Informatique/Calcul parallèle, distribué et partagé
  • hal-00344362, version 1
  • oai:hal.archives-ouvertes.fr:hal-00344362
  • Contributeur :
  • Soumis le : Jeudi 4 Décembre 2008, 15:45:50
  • Dernière modification le : Vendredi 5 Décembre 2008, 08:12:35
tous les articles de la base du CCSd...
